merlecollins
But can you fit say a Porcelanosa 666mm tile in to cut?but deffo 660mm.
but can you fit say a porcelanosa 666mm tile in to cut?
Eh?:smilewinkgrin:Theres allways one
But at 45 degrees it chips quite a bit when trying to do external cuts and yes I tried tiles up side down as well, and as I do a lot of external mitres with natural stone has anyone had the same problem and solved it with a blade change and if so what Blade do you use
