dunner
Hi all,
this is my first post , so forgive me if i waffle a bit .have spent hours on this site taking invaluable advice already to fit new shower tray & tile 3 sides ..but : i removed old tray in ensuite which was in corner between block wall & studwall .damp had set in & patch of skim plaster on block wall has crumbled away,rest of skimmed wall is ok . i believe its not great to tile onto skim plaster anyway so i need to prep block wall for tiling . i plan to tank shower walls with KERDI .whats the best way to prep this block wall for tiling?? should i remove all skim from wall , then dot & dab ordinary plasterboard & tank??if so whats best way to remove skim ..or should i use wood battens to fix new plasterboard to or should i repair skim,if so how ??
ta very much in advance .
