Discuss Cutting 900x900 Tiles in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
V
vala
It's looking like I'll be using 900x900, 10mm thick slate tiles for my wetroom.
Can anyone recommend a tile cutter which would suffice? I'd like something with a guide to get any edges straight if that's possible.
J Sid
What you fixing to?
You will need to watch what products you use in the shower and if you are in a hard water area that can make the slate not look good after a few months.
V
vala
Plan is to use the following slate tiles
I do intend to seal the slate after it's been laid.
I have Orbry boards covering the ceiling, walls and floor. The slate will be fixed directly to the Orbry boards on the walls.
On the floor electric UFH will be laid, followed by a circa 2-3mm covering of SLC, before the tiles go on.
Reply to Cutting 900x900 Tiles in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
