Discuss Customer Vs Trade Dispute - Natural Stone Tiles in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
templar018080
Hi all,
I understand that BS5385 suggests:
Variation across Joints:
±1mm for joints less than 6mm wide
±2mm for joint 6mm or more wide
However, what are the guidelines for natural stone tiles, i.e. travertine limestone which are 610mm long, 406mm wide and 12mm thick, with a joint of 2mm between tiles?
I would have though the guidelines would be different since natural stone is not even in depth across the whole tile.
I have a customer who found the BS5385 spec on google and is now trying to use it as an excuse for not paying. In fact he is threatening to take me to court for the costs of rectifying the job.
I tiled the gentlemen’s conservatory floor with this natural stone, 20 square foot worth and only one or two of the tiles have a variation of about 2 mm.’s
thanks
DHTiling
You cannot find BS5385 in google but you will get snippets of certain requirements from it..
Is it travertine or limestone..? and what finish is it.. honed or polished, maybe even brushed..?
mikethetile
should be able to get the floor re honed but I will leave that with the stone experts as I have little experiance with stone
DHTiling
You can sand the stone down in these area's quite easily..
Wet and dry sand paper and a sanding block, start with 50 grit till down to height and then work up in grades till around 400 grit and feather it back into surrounding tiles... this will remove the lippage and hopefully get you a happy customer.:thumbsup:
templar018080
Thanks, I had the same thought process and even offered someone else's skills to do a sanding job, but the customer was not happy with a sanding solution. The customer wants to have the floor re-tiled which I have told him is ridiculous.
After a few weeks elapsed the customer has sent me a letter saying i had the opportunity to rectify the job and now wants to put in a claim against me for re-tiling the whole floor!!!
Scott
As long as the customer give you the opportunity to do it. I think from previous reading he has to give you the chance to put it right?
DHTiling
That is ridiculous..:mad2:
A couple tiles with lippage can just be replaced if sanding is not an option and the customer is being well OTT ..
Send a letter stating how you can rectify the floor.. send it recorded delivery so you have a record of events.
That customer does not have a leg to stand on for a re-tile through the courts..
Dan
Admin
He wouldn't have a leg to stand on in court. In fact, from what it sound like, you would actually have the better case.
If you suggest a fix, and the customer doesn't accept, it's their fault the floor is still like it is in some sense. To rip the floor up and re-tile it which could end up with even more lippage isn't the best solution for either side of the argument.
I'd say to him "I'm coming monday to fix the floor" and then just turn up and do it.
mikethetile
you only need to rectify the faults
write back to them using registered post to tell your customer you are sending someone to rectify the problem
give them 3 dates to choose from and say if they are not conveniant which date do they suggest
you dont need to go into details just state that the lippage will be removed
this will stop their claim in its tracks and prevent them from going to court unless they give you the oppurtunity to rectify and you fail to do so
templar018080
I agree Scottley, I told the customer I would do the sanding, but he never gave me the opportunity as the customer only wanted me to relay the floor to which i said no of course.
Reply to Customer Vs Trade Dispute - Natural Stone Tiles in the America area at TilersForums.com
Apatel
