Discuss Crumbly Adhesive - Experienced input needed in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
mccaber
Hi,
I have tiled several hundred square metres of tiles, wall and floor, over four houses and never had any problems..until now.
I recently decided to tile an ensuite. The surface was osb and the floor has a run off.
I laid backerboard onto the osb for a nice surface.
I decided to use two bags of good quality powdered flexi floor adhesive. They were stored dry in my shed for about 18 months.
The problems.
Where the tiles were laid with a light bed the adhesive is dry but crumbly. Where I had to use a thick bed (floor run off) the adhesive is still spongy after two days. I think the hardener died in the shed.
The tiles are solid and stuck to some extent i,e, they don't move.
My 64 thousand dollar question... will i have to pull them up?
G
Gazzer
I think the sensible thing would be to remove the tiles and retile with an adhesive which is within its use by date.
mccaber
Thanks for getting back to me.
That's the advice i was fearing! Has the hardener expired? Do you think the adhesive will compress and break the tiles eventually (this is what I think could happen)?
G
Gazzer
You would need to talk to the maker of the adhesive for such technical advice. It "may" set and be fine but then again it " may " fail .
mccaber
Thanks again.
I am trying to make my brain do the right thing (retile). Its just taking a while to get over the psychological bridge!
CJ
Wot make of addy?
at least if it's an en-suite......it won't be a massive area.
Probably have to cut ya losses and re-do.
mccaber
Wot make of addy?
its arc ..irish brand. Its good stuff, but out of date. Thanks for the advice i dont want to hear. The more i get of it the more likely i am to do the right thing.
"Just do it!!" "Just do it!!" "Just do it!!" "Just do it!!" "Just do it!!" "Just do it!!" "Just do it!!" "Just do it!!" "Just do it!!" :rofl:
Well in my defence, u did say............
Andy Allen
I would just leave it .....I will harden in time and be fine...:thumbsup:
only joking , its pants and will always be pants, best to do the right thing and re-do it.......made you feel better for a second though, didn't it...:lol:
mccaber
Even after all the sensible re -do it advice I really wanted to believe someone who would say it will be all right.
I get it.
Rip them up. . .or gently pull off. Thanks to everyone who responded. .even this one. It did raise a smile.
U
Unused Account 1
I
Hi,
The problems.
if not set in 72 hours ,lift them ,good luck
I
@Protiler 68
Hiya mate I realise you're new and the forum can be confusing at first, so here's a little tip.
When u find a thread (subject) u'd like to read, there are two things to look at before u do.
Firstly the date the thread was started, that's the circle on the left.
Secondly the date the last reply was given, that's the circle on the right.
If there's no real conclusion to the thread there's absolutely no reason why u can't ask the OP (original poster) how he got on.
If u check those dates tho it might help u decide whether or not to reply!
But still read it tho! It doesn't mean u won't find it interesting, just means it's probably resolved.
Just thought this might help! ;)
Keep active tho mate, good to see you involved!!
Joshua
@Protiler 68
Yeah but I want to know information about crumbly adhesive and it not setting too. So this answer and thread is useful even in 2022. Google found it for me.
Reply to Crumbly Adhesive - Experienced input needed in the Canada area at TilersForums.com
andymtl24
