Discuss crackle tiles and dark grout: patchy staining in the DIY Tiling Forum area at TilersForums.com.
rsk
sheffield
I have used dark grey grout with crackle metro tiles, the idea being that the grout stains the cracks before applying sealant and gives it an aged look. However, the tiles have stained very irregularly: some tiles just atined in patches, some have not taken stain at all. Any ideas what i can do about this to get them to stain? i have tried reapplying grout to the tile surface but no joy
Unfortunately doesn't show up too well in photos
57
258
Cheshire
You can't guarantee an overall even result because of the firing process for the glaze, also the manufacturers are probably trying to counteract grout seepage rather than encourage it. Try using a runny consistency of black grout on a spare tile: if you can't get the effect you're looking for I'd advise you to give up or you'll end up replacing all the tiling work because it will look awful. Good luck.
Reply to crackle tiles and dark grout: patchy staining in the DIY Tiling Forum area at TilersForums.com
Help! Advice needed please! I am in the middle of a bathroom renovation that my partner is...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
Last Dec tiled a small conservatory (13m) with 600mm porcelain tiles. Prior to tiling another...
Advice needed, noticed some grout that was cracked and tiles becoming loose in our en suite wet...
Just had following work done: downstairs toilet - replaced toilet and sink and tiled the floor...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Tilers Forums on FB
