Discuss can you cut curves in travertine tiles? in the UK Tiling Forum area at TilersForums.com.
A
anhewitt
hi there,
is it possible to cut travertine tiles on a curve? the tiles are 13mm thick and 200 x 100 in size.
DHTiling
YES..no probs...just use your wet cutter and cut the basic shape out, then skim cut along the blade to get the shape......takes time but can be done.....or you could use a grinder but not as accurate as a wet cutter........
Reply to can you cut curves in travertine tiles? in the UK Tiling Forum area at TilersForums.com
  • Poll
I'm searching for 42 pieces of 12" x 12" Verde Alpi marble tiles. Preferably honed. 12" x 24"...
