Discuss Brick Slip Sealer advice? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
MikeMounty
Hi all very new here just signed up to ask a question!
I am wheelchair-bound due to a disability so unfortunately I do not know anything about building work!
I have just had a bricky complete the last room of my renovation. He was placing brick slips on the wall.
I'm now looking for a sealer for the slips that will basically seal the bricks from producing dust and damage when you brush against them.
I have been tempted to ask the bricky to use the PVA primer as a sealer but I was told from my friend it is not a good idea.
As these brick slips are in doors and will not have any water exposure... does anyone know what type of sealer I should be looking for?
I also cannot have a sealer that is constantly potent smelling two months down the line due to my breathing.
Any help would be greatly appreciated,
Kind regards,
MM
Lithofin BOB
Hi mike, this is a tricky one,
To bind the dusting fully you would need a topical sealer,this will give a shiny finish, not sure you want a Shiny wall!!
Assuming they are fully dry and released of all moisture, You can test an impregnator ( impregnating sealer), but the binding is not as good. People do use them for this , I would buy a small tests bottle and get the builder to test this on 3-4 bricks , apply one coat leave 24 hours and apply a second.
Due to the solvent in these , I would recommend a water based product to test. These polymer based products should show some improvement without colour change or smell.
As for the PVA , I have stripped lots of shiny patchy walls due to the use of this .
Reply to Brick Slip Sealer advice? in the Canada area at TilersForums.com
laattaana
