big scratch removal - how?
I must admit I was a bit apprehensive about going into my local dealer and asking for a large rubber.
But like most of these pro bits of kit - they are worth having - so I will keep both eyes open :yes:
Should you require one!! , then here you go....... Link removed
The clear winner, beings none of the others appeared to work was by using a product I bought for cleaning the chrome bits on my frogeye. Similar to solvol autosol - I used 'Peek' - it says it cleans, polishes protects all metals, fibreglass and ceramics.
I used my dremel with a small buffer pad soaked in Peek set to a medium speed and after about 10 mins half the job is done. Well impressed.
Take my thanks for this idea, Martin:thumbsup:
Hi had the same problem with slipping with a grout rake. Left two black marks over glazed wall tiles..
Initially thought an eraser . You know the type - one for pencils and the other end for ink.. no such luck !!!!
Next step good old T Cut - no luck there
Used wet n dry P1000c / 164 which is superfine and with a very wet application removed it.
This way worked for me but these were surface marks on top of the glaze so may not work on every situation.
Luck it works a no spares
Best of Luck
Andy
Hi tiler
yes you are right - it was a metal mark from slipping with a grout removal tool. So if I confused anyone with the 'scratch' description then sorry about that. It looked like a big scratch to me.
I had tried wire wool on an old tile and the results were disasterous - an even bigger mess.
As promised I tried as many ways of removing my 'scratch' as cheap as possible. Tried bath cleaner, toothpaste and t cut and car polish
Hope this info helps
frogeye
Hi frogeye - I need to say a massive thank you to you! I am not a tiler but recently had a new bathroom with white matt ceramic tiles, which I scratched with a metal edge on a squeegee. I have been all over Google and tried Cif, toothpaste, vinegar & baking sofa - all to no effect. Looked at tile repair products but couldn't find matt white. Looked again today (in desperation) & found this site & saw your post about Peek polish. Took a few attempts but they are brand new again! Delighted. Thank you so so much!
frogeye,
Caroline 63,
frogeye,
Caroline 63,
