Discuss Best way to apply adhesive , floor job in the Tile Adhesive / Grout Advice area at TilersForums.com.
Explain where we are all going wrong then John.
Never said you were - just asked why because others might not know!
Me I do it up, down, sideways , swirls, flat backed, ribbed and a bit extra in the corners when required. As long as it's solid bed there should be no air pockets and I wouldn't make the adhesive stiff enough for the ribs not to collapse.
You'll only need to back butter that tile with the flat side of the notch so as to leave a thin skim.Thanks for the responses chaps, so the General consensus is, spread the floor with 10mm notched trowel, then also back butter tile with notched side also, and make sure notches of floor and back of tile run in the same direction to allow air to escape for maximum compression?
This is exactly how I was taught to do it 20+ years ago and it's how I still spread addy today.To allow the air to escape therefore allowing the notches to compress for a more solid bed. Swirled like spreading patterns cause the air to be trapped and the compression resistance won't allow the tile to fully colapse the notch and in turn prevents a true solid bed.
Reply to Best way to apply adhesive , floor job in the Tile Adhesive / Grout Advice area at TilersForums.com
