best bonding agent for ply floor
groutpad
what do you think is the best bonding agent to seal a ply floor befor tiling and how long before tiling does this need to be done ??:whatchutalkingabout
Always check with the adhesive guidlines.....BAL don't recommend priming the face of the ply , just the back and edges...Some adhesives say to prime like ardex say use p51....always check first.........IF you do prime use a primer that suits the adhesive ( same make ).........
I'm with Dave too. My normal combo is Ardex P51 with Ardex-flex7001.
i always read manufactures full technical data before using any adhesive most are available on the web thats where you will gain most of your knowledge you don't learn this by trial and era 😛ete
ive got a job where a joiner is laying ply soon b4 i tile it with ceramic floor tiles,. my problem is b4 he layes the ply does it make a differene wot he primes the under side and eges with? i dont mean pva!. i mean does it have to be the same stuff recomended by the adhesive manufactures for the addy? .. is just normal wood primer ok for this ? oviously i would be priming the face of the ply if needed with the correct primer to go with the flexi addy ?
Terry - I know its not always possible and people don't want to pay tilers rates, but I always go in at a competitive rate to put the sub floor down.
That way you can get the joints in the right place and not half a dozen boards meeting at the first step into a room!
Not getting into any debate about sealing the underside of plywood today - its Sunday - but I'd advise Hardie backer boards in 2009.:thumbsup:
Timeless John.
The Best bonding prior to tiling on a plywood floor in my opinion is 6mm No More Ply or other 6mm tile backer boards.....everytime.... it is without a doubt the best surface regardless of substrate to tile on..........:hurray::8:
Hi Tel,
1. You are lucky the joiner is willing to prime the edges and undersides.
2. I cant see it matters which brand he uses as it wont come into contact with your adhesive, (ok a tiny bit on the edges) It's only to stop moisture ingress from the underneath.
Keep up the good work in the arcade, I will be playing catch up when I get chance.:smilewinkgrin:
Gary
[email protected]
groutpad,
smurf21,
groutpad,
smurf21,
