Discuss Bath shower tile adhesive and grout in the Tanking and Wetrooms area at TilersForums.com.
K
kevoffthetee
afternoon all, I'm hoping for a little advice for tiling above my bath. its a new brick and block extension and the plasterer has dot n dabbed.
Since I've always had house which were properly plastered I havent mounted the bath onto the wall yet due to panicing about moisture, although I've tanked the walls using the ARdex kit from CTD.
Would it be overkill to use a powershower adhesive and seperate grout? what brands would anyone recommend to a good DIYer other than mainstream mapei, bostik A200 etc
I like the idea of the bostik A200 range as its labelled as powershower but is that jsut a marketing gimmick
thanks
Kev
G
GoneGuy
For wet areas I would recommend using a powder bag adhesive and also use standard set as you won’t waste any
K
kevoffthetee
thanks for the quick reply. should I also use powdered grout or ready mix or does it not matter? are there any that are more water repellent or mould resistant? out of ease and laziness I was looking at Mapei range at screwfix but obviously it has to be right so would rather buy the right stuff
G
GoneGuy
I would use powdered grout as well.
Also stick with well known brands ( not b&q etc own brands)
What tiles are you fixing
G
GoneGuy
I use Mapei ultracolor grout a lot,
For that size tile you would have to use a bagged ( powder) adhesive, also make sure you back butter the tiles to ensure full coverage.
Waluigi
have ready mixed adhesives actually advanced much in 15 years? That’s probably the last time I bought a tub. I remember white star being pretty good and Ardex D20
Waluigi
Agree with Adey in terms of slow set powdered and powdered grout. A pro wouldn’t consider anything less and neither should a DIYer.
Time's Ran Out
Ready mixed for ceramic only and no bigger than 30x30!
Keep asking questions because you need as much help as you can get.
Reply to Bath shower tile adhesive and grout in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
