Currently reading:
B & Q Readymixed Floor Tile Adhesive
Discuss B & Q Readymixed Floor Tile Adhesive in the UK Tiling Forum area at TilersForums.com.
daveshades
B&Q tile products are definately for DIY'ers not for pros. I have seen it a few times in the showroom where customers buy a nice tile but not the adhesive, then go to one of the big DIY stores to by the materials to stick them down with. Then they end up coming back to us a few weeks later wondering why their tiles are lifting! The big DIY chains can't offer the right advice either, they are not specialists in any paticular area. Unfortuniately they do more harm than good to the industry.
69
1,043
I know of a tiler local to me who tiled a whole bathroom in a day with b&q gunge, got a phone call the following day saying that all but 8 tiles had fell down, he hadn't grouted...got the manager or someone from b&q to have a look and they decided that it was a bad batch, they have agreed to pay for the tiling to be redone and a new and installed shower tray. This was 2 wks ago..
sjorlo
I've just had a response from B & Q after they've had one of the tiles tested. They said (amongst other things) the adhesive was laid too thickly and should be laid to a max of 4mm (is this correct? Doesn't sound very thick to me). Best bit is the trowel used was a B & Q own brand trowel with 9mm notches and on their website it states - "Notch size ideal for floors"!!!!! They are now coming back to me - again!
Olz
What does it say on the side of the tub?
Olz
IMO you need to get the tiler back, point out to him that he should have known better than to use the adhesive at the thickness, and that he hasnt allowed anywhere near enough time for it to set prior to grouting.
I dont know what the conversation was between you and him in respect of the adhesive but to be honest the majority myself included would have pointed out to you that the adhesive was rubbish and explained why, got you to take it back and supplied you with a suitable adhesive most likley at less cost.
sjorlo
Best bit is, they told me what to buy! Had I tiled the floor myself (I really wish I had) I would have done the research and bought the most suitable product for the job, which is why the wall tiles are still up and look spot on (I decided to do them myself after I saw the job they did on the floor) but when someone who professes to be a tiler tells you what adhesive to get, then (rightly or wrongly) you go with that.
Colour Republic
So the tiler suggested the choice of adhesive?
Colour Republic
Yep! "Get tubs of readymixed adhesive and grout".
Blimey! So not only did he spec B&Q but also went so far as suggesting ready mixed addy and grout!!! As has already been mentioned on here a thousand times, NO pro tiler would spec premixed addy and grout.
Sometimes you will get customers that have supplied their own materials and even if you point out that the product is flawed, sometimes the customer will insist you use it. Now in this case what the customer wants, the customer gets. But I’m sure I speak for the majority on here that if the job is done with such materials, that we wouldn't offer any sort of guarantee
The majority of floors would require more than 3mm of adhesive, you would only get away with 3mm on the flattest of sub-floors, that said if it does state maximum thickness on the tub, I’m afraid that the ball is firmly back in the tilers (I use that term loosely) court. I have a feeling that the guy is not a tiler and you already know this as alarm bells should have rung when a) he asked you to get the materials yourself and b) he asked you to buy a trowel as well! A tiler without a trowel is a bit like a painter without paint! By the way even though the trowel was 9mm (if used correctly) once the tiles had been laid it would leave an adhesive bed of between 4-5mm.
Was this guy just doing some odd jobs around your house and said he could tile the floor for you? or is he advertising as a tiler?
StevenBarn
Hi Folks, I hear you loud and clear that the tubs are a complete mistake for floors but is the readymix addy ok for walls.?
I was told "tubs for walls", "bag of self mix for floors". Do you agree with that and if so, is the 'unibond readymix tub for showers and wetrooms etc' any good? Also, is there a bag self mix for walls, or is it only made for floors? And can you use the floor bag mix for walls? Thanks for your help, Steven
Reply to B & Q Readymixed Floor Tile Adhesive in the UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain. I took...
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
