Arrows on back of porcelain tiles
the arrows on the tiles show the way they where glazed and fired on hight glaze tiles can look like diffrent shades on walls if you dout follow the arrows next time you come acrross this put a tile under good light with the arrow facing up then turn the other tile round stand back and look at the shades see if it changes with the way the light hits it
this sounds like a good answer. who told you this ray.
doesnt it mean though that you may need to allow for more wastage than normal and have to ask if there are arrows on the back before you decide how many sq mts you need .also have to mark every off cut you have left over where you have already used part of tile with arrow on it!!
i had this recently on a big floor and we certainly used more than normal because we had arrows in same direction
Good to get some sensible feedback, thanks to Ajax123 for link, thought that was
the case, but will still check tiles before laying
I allways mark off cuts, so i know where arrows should be. If i start walls with arrows UP, i ceap it that way. ( only some off cuts stick with arrows down, but don't turn to left or right)
good point ray tt :thumbsup:
I think because of the way they are fired whilst the arrows are for production purposes this firing procedure will "grain" the tiles such that they are not uniform across the entire tile. As each tile is subjects to the same regime these arrows can presumable as has already be mentioned be used to align the tiles so that the grain is unidirectional. I suspect that it would take an extremely keen eye to determine differences on a floor. Not sure about walls though... I don't deal with walls often.
i have had porcelain tiles quiet a few times a few years ago when they were like parallelograms the only way they could be laid was buy putting them all the same way
another point is that on a 60x60 06 60x30, any bowing on tiles is normally the same on each tile so keeping arrows directional helps with lipping!
Dave H,
Rizzle from the Portizzle,
Dave H,
