Discuss Another mosaic. in the Australia Tiling Forum area at TilersForums.com.
dboden
Points
493
Nottingham
I have a job tomorrow, the tiles are 700x300 with a mosaic border.
But these are 600x300, similar to those in the link below.
They are also the same thickness as the tile.
Any tips for fitting these.
I usually put the backing sheets onto smaller mosaics!!
I would usually lay tiles this size using an 8mm trowel, but I assume this would be too big for the border?
Would you cut these with a grinder?
Also would you tile below and above first, as the other post..
https://www.emctiles.co.uk/main/product/productinfo/1793/Kaleido%20Grigio%20Lap%20-%20Rett%20Listellato%2030x60/1
Any help or tips appreciated,
Thanks in advance.
Just Rizzle
just done a bathroom with them last week no need for mesh
spread wall with 1o mm trowel above last row of tiles.place in mosaic and support between joints with 2 mm spacers .fit tile above so as you get the mosaics flat as the mosaic has the spacers to support above tiles weight. the addy we used was weber spf rapid
White Room
What mosaics were they????
Reply to Another mosaic. in the Australia Tiling Forum area at TilersForums.com
