I have a floor to put down and I'm after reassurance regarding procedure.
Anhydrite floor with a 1200x600 porcelain tile on it.
so.... prepare the floor with a machine to take the surface crystals off (about 2mm) then prime with a suitable anhydrite floor primer, ill probably use bal. lay ditra matting with anhydrite adhesive roller the matting in for extra bond, then tile the floor in the normal manner with a flexi slow set.
3 fall this is directed in your direction. Is this correct or does it need tweaking?
thanks.
thanks.
