Discuss Advise on Dural ci fh. in the Tiling on Underfloor Heating area at TilersForums.com.
If it has insulation underneath is it a floating floor .There is a insulation underneath the chip boards also wanna keep floor as low as possible cause there gonna be a step at some point.i'll check your product.thanks
What's the reccomended cable spacing on the mat for such a thick tile?Should be fine, If you can it maybe worth to put a tile backerboard in just to stop the heat escaping downwards. We've got a alternative to dural if you'd like to take a look, will most likey be better priced and a higher quality product.
Electric Undertile Heating Cable with HeatBase Decoupling Membrane - http://www.uheat.co.uk/electric-undertile-heating-cable-with-heatbase-decoupling-membrane/
You reckon it's too risky going with uncoulpling membrane only?If it has insulation underneath is it a floating floor .
Yes it is.Is it a floating floor
I appreciate your advice,after this thread i have done more research and was going to let it go,however may consider fixing it. What would be your advice to do that?don't even consider Tiling a floating floor.
there is a very high chance of it failing.
are you a gambling man? Is the few hundred pounds profit good enough against the few thousand you will have to pay out when it goes wrong.
only option is it needs to be changed into a fix floor before tiling
Reply to Advise on Dural ci fh. in the Tiling on Underfloor Heating area at TilersForums.com
