Discuss Advise on Dural ci fh. in the Tiling on Underfloor Heating area at TilersForums.com.
andreas
Hi.will dural ci fh membrane be enough to use straight on chipboard floor which looks pretty sound with 1.2m over 0.6m, 10mm thick porcelain on top? 20m2 coverage.
Andrew
Uheat - Jake
TF Official Sponsor
andreas
There is a insulation underneath the chip boards also wanna keep floor as low as possible cause there gonna be a step at some point.i'll check your product.thanks
If it has insulation underneath is it a floating floor .
andreas
Should be fine, If you can it maybe worth to put a tile backerboard in just to stop the heat escaping downwards. We've got a alternative to dural if you'd like to take a look, will most likey be better priced and a higher quality product.
Electric Undertile Heating Cable with HeatBase Decoupling Membrane - http://www.uheat.co.uk/electric-undertile-heating-cable-with-heatbase-decoupling-membrane/
What's the reccomended cable spacing on the mat for such a thick tile?
Uheat - Jake
TF Official Sponsor
We normally space it at 2 spacing minimum which gives off around 140-160w/m2 which is a primary heating source.
J Sid
don't even consider Tiling a floating floor.
there is a very high chance of it failing.
are you a gambling man? Is the few hundred pounds profit good enough against the few thousand you will have to pay out when it goes wrong.
only option is it needs to be changed into a fix floor before tiling
andreas
I appreciate your advice,after this thread i have done more research and was going to let it go,however may consider fixing it. What would be your advice to do that?
andreas
Reply to Advise on Dural ci fh. in the Tiling on Underfloor Heating area at TilersForums.com
Bob Marley
