Discuss 70m2 Floor, 2 substrates, Ditra and Hardie? in the Canada Tile Advice area at TilersForums.com.
C
clipboard2008
Hi
I have a client who needs me to tile his kitchen. Part of it is caber floor T&G (original part of the house) the other part (extension) is sand and cement screed. The extension comes off the front and side of the house so the join between the timber and screed is in an L shape. There is also wet underfloor heating under all the floor.
Tiles are 600x600 Porcelain
How is the best way to stabilise this floor?
The client doesn't want an expansion joint over the join in the 2 substrates as it would be in an L shape and ruin the look of the tiles
Is it going to be a case of fixing Hardibacker across the whole floor, bridging the join then covering in ditra?
Would this stabilise it enough to ensure no future cracking?
TIA
F
Flintstone
That is the question, what is the underfloor heating system set up on the wood side ? If you are over boarding with hardie, you shouldn't need ditra, imo! But an anti fracture mat over the area where your bridging the two substrates wouldn't hurt.
Dumbo
If you can see it flexing you got problems possibly with the suitability of the timber floor for tiling . Just to be clear does it have ufh on timber floor .
C
clipboard2008
UFH is under the caber flooring and is also in the screed.
On the timber side it is polypipe laid in a metal tray then sand cement to top of the joists so heat transfers to caber flooring.
Chris Gibbs
598
North wales
in my opinion don't use ditra... sorry, but it doesn't stick to the matting that well for me to have piece of mind. some may disagree, that's my opinion and experience. id go for a durabase dural matting...
Dumbo
I think you need to set your tiles out in both directions that joint is on substrate change and use dural microjoint or coloured silicone instead of grout .
G
GoneGuy
How big is the area with the caber floor? Is there a possibility of filling it in? To prevent any bounce as that is where your going to coma across with problems
Reply to 70m2 Floor, 2 substrates, Ditra and Hardie? in the Canada Tile Advice area at TilersForums.com
