600 x 300 ceramic wall tiles.
boart
Hello.
I am in the early stages of fixing 600 x 300 ceramic wall tiles to bathroom and ensuite walls in stretcher bond. while I have done a fair bit of tiling before (but not with tiles of this size) I'm finding it far from easy to not get any lipping. I am very fussy and strive for perfection but realistically how likely is it for me to fix this size tile with no lipping at joints and what would you trade guys consider acceptable, thanks in advance.
Thanks for the reply whitebeam, I will check that. I'm tiling onto a stud wall lined with fermaboard which I've sealed. Pretty sure the wall was slightly bowed along the length which I tried to overcome by laying tiles and then checking along length with a 2mtr level and dubbing out as required. All looked good, but then on went the next row and there was a bit of lipping here and there not much 0.5mm or so. Is this to be expected with tiles of this size? will it get taken up when grouted?
The walls should be as flat as poss for the brick pattern, it could mean you may have to build out the odd tile. Wlth ceramic I find it can be hard to buy them perfectly flat at that size, try to keep your lighting as it will be on the finished job. The grouting might hide small imperfections but not larger lipping which should be avoided at all costs
I started with a 10mm trowel when putting the first course on, but went to a smaller trowel as I thought the 10mm was leaving to much adhesive on the high spots due to the bow in the stud wall which in turn meant dubbing out the low spots more than I wanted.
Bal rapidflex, Hard to say but about 4 or 5mm in the middle of a 3.0mtr run at mid height in the stud wall (a bowed stud i guess, typical) the stud wall follows a sloping 35 degree ceiling up to a height of about 3.0m so I should lose the problem the higher I get. I thought I had the first course back OK with a bit of dubbing out, but it seems with tiles of this size a small amount out just gets magnified when the next course is added.
Reading the questions and replies through - post 2 from Whitebeam asked if the tiles were flat?
If they are ceramic and 60cm long it would be unusual for them to be flat and not bowed in the middle and unfortunately brick bond is not a design that allows perfection with this material.
If they are porcelain and 60cm long and they have a sharp square edge any bow in the tile will again cause 'shadows'.
You usually find the more expensive quality porcelain give a flat surface but if your preparation is uneven it will be almost impossible to put it right with tile adhesive.
boart,
TheFunkyMonkey,
boart,
TheFunkyMonkey,
