Discuss 50mm thick french limestone ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
bluesky
503
cambridge
hi all , ive been asked to quote for 21 m2 of 50 mm french limestone ,- not tiled anything that thick in my 14 years - any advice ?
Dan
Admin
1,318
Staffordshire, UK
How even is it? You want to go through it and find the thickest ones to start the floor with, as you can always build up the rest with adhesive, but doing it the other way around you can run into issues.
If it's quite even it shouldn't be too much of a problem from that point of view.
bluesky
503
cambridge
just a tender on paper at the moment , got a site visit soon to meet the builder etc although not sure there is a lot to look at yet . ditra is not on their spec but would be on mine !think they want an estimate to give themselves an idea
Dan
Admin
1,318
Staffordshire, UK
A tender for 21sqm - Seems a bit fishy. Is it somebody you work with often that's putting in the tender? If not I'd suspect they haven't got a clue and want you to price it all up, so they can then go in with a price themselves and spec that'd sort it out.
If it's nobody you've dealt with before, pinch the customer yourself and spec it properly and explain why. Tell them a price 3 times the one you're putting in and put them off lol
J Sid
internal or external?
if different thickness would be best to fix in sand and cement.
if similar thickness fit as normal but leave plenty of time to dry before sealing.
bluesky
503
cambridge
not worked for the builder before - i dont generally work for builders - prefer to go direct to client and explain everything ( like tanking showers , decoupling etc)
might give this one a swerve!)
cheers
Dan
Admin
1,318
Staffordshire, UK
You could do with perhaps getting as much detail off of the builder or the customer and coming back with everything you can. Then see what the score is from there. There could be money in it. But don't spend too much time messing around for somebody teaching them how to do it themselves if they're possibly just going to ditch you and stick a price in themselves.
F
Flintstone
Why would you want ditra under a 50mm thick tile?
I've tiled internally with 50mm thick stone and it's just like any other tile but heavier! I'd bet they will be uniform thickness.
Dan
Admin
1,318
Staffordshire, UK
I simply asked what the substrate is and said he might need Ditra. Limestone isn't the toughest stone by a country mile. Doesn't matter what thickness it is, if it's going to split the first 5mm, the rest is going to follow suit perfectly.
Reply to 50mm thick french limestone ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
Hi all. As title suggests. Used to use this forum a while back but seems my account was deleted...
