Discuss Grout joint width in the Tile Adhesive / Grout Advice area at TilersForums.com.
Thanks for the reply, much appreciated.I'm fixing some 1200 x 200 planks with a 3mm joint so if you reduced your grout joint to 2mm you would still have more grout width per metre than me
That is exactly what i will be doing, thank you.As long as you fix the tiles correctly and have a perimeter expansion if going to skirting boards should be fine
It's an "s" shaped hallway approx 9 sqm. Largest area 2m x 3mHow big an area is it ?
Ok , just checking it wasnt a large area , too tight a joint could cause tenting.It's an "s" shaped hallway approx 9 sqm. Largest area 2m x 3m
Thanks for your concern. I would just add that the sun shines in from first light so the tiles will get quite warm in the summer.Ok , just checking it wasnt a large area , too tight a joint could cause tenting.
Reply to Grout joint width in the Tile Adhesive / Grout Advice area at TilersForums.com
