Discuss Length of time between applying primer and fixing tiles in the Canada Tile Advice area at TilersForums.com.
188
London
Everyone deserves a second chance.
Except cowboy tilers. :mad:
they were adamant nothing was wrong with them and still haven't formally admitted it either, but at least they have agreed to start replacing tiles in high traffic areas.
To be honest since I haven't paid for the tiling or the retention fee, I will make them redo the whole floor before they see any money.
acaciaguy
558
Warwickshire
Do you have any pics of the tiles that came up etc. You said they were incorrectly fixed. In what way was the coverage not good? How we’re they fixed.
188
London
I had a previous post on the matter here. There were quite a few issues that came up but the main one was lack of adhesive coverage. Some of the tiles that were taken up had barely 30% coverage.
408
Manchester
There is were the problem lays, if they are coming back to refit work that they are adamant there nothing up with why they coming back at all or subsequently if what you have said about the lack of adhesive coverage on the tiles originally why are you having them back
188
London
the architect who's managed the project said I need to give them the chance to rectify the problem. I've got them to redo just the hallway first (about 8 tiles) and since I work from home and have cameras fitted everywhere I can monitor their work.
sadly, I'm not sure if I'm in a position to demand they hire a professional tiler to carry out the works
188
London
Do you trust they will do a good job ?
they either did a rubbish job the first time because they were trying to cut corners, or they are simply incompetent and are tiling based off what they'd seen on youtube (which tbh should have resulted in a better job than they originally did)
they'll be refixing a small section initially so I can ,with my limited experience/knowledge at least check the've done an adequate job before they do the rest
Reply to Length of time between applying primer and fixing tiles in the Canada Tile Advice area at TilersForums.com
