- Reaction score
- 23
Ok guys, after reading some of the replies to my other thread I need to do some re-thinking. I intend to do the best job I can, and because of the weight issue of using large porcelain tiles on my plastered walls I am thinking of removing all the plaster and fixing plasterboard direct to the Thermalite block walls.
I would like to fix the plasterboard by screws to the walls rather than using an adhesive or dot and dab method, (it might be my engineering background that makes me think it will be stronger) Am I then correct in thinking that this will then hold 30kg per sq/m? even over the Waterguard?
