• Thread starter Blunt Tool
  • Start date
  • Replies 26
  • Views 4K
  • ufh
Discuss Anyone got their eye on a piece of kit from Santa? in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
Blunt Tool
Blunt Tool
Interesting..how's that work then if the wires are broken and cold?
I've heard there's ufh repair companies that put a large voltage through the ufh cables and find the break somehow?
Sometimes you get lucky Andy and the heating will go on for a while then switch off suddenly but it will leave a heat signature
Blunt Tool
Other times when not so lucky electrician will check continuity of cables and sensor then if still no fault found disconnect sensor and thermostat and run current thru cable and use a live voltage detector
Blunt Tool
Ah right, sounds a lucrative market....as long as builders, sparkies plumbers and joiners are installing ufh sure they'll be a constant flow of work ;)
I cannot do the electrical side only play with controls etc see if I can get it to run a while, after that electrician must come to help me
Reply to Anyone got their eye on a piece of kit from Santa? in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
