Discuss Recommended cutter for 1200mm porcelain in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
L
LM
Some tiles are over tensioned and simply wont cut clean and if that Sigma can’t dobit I’d say it’s likely to be the problem. Marazzi are famous for it.
Waluigi
Disagree ,its the tile
The back looks like one I had 18 months ago . It didn't cut .
Maybe I don’t know, im just saying that the size of the tile he is trying to cut is 1200mm. Nothing more than that.
That’s unfortunate though. The very first tile that is being attempted to cut is not able to cut. What a bummer
Lairdy1
88
Essex
This is almost certainly 1 of of them tiles.it just wont snap a small cut cleanly. The only thing i would try other than a wet cutter or grinding the whole tile. I would scribe the tile as normal.then run your grinder about 1 to 2 inches into the tile then place the snapping handle just in front and snap there.its worked for me in the past.
James De
588
London
That’s my kinda luck Waluigi :D
Reply to Recommended cutter for 1200mm porcelain in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
