Discuss Recommended cutter for 1200mm porcelain in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
So is the top of the bar supposed to sit central to that square when the breaker is resting on the tile?Thanks Antonio
I haven't, no. I didn't know there was one. So the top of the bar is supposed to sit just under the top of the square on the handle?Have you been on the sigma thread I created? I can’t remember. The height adjustment has been mentioned a few times. Makes all the difference.
The manual isn't great. It's just a series of pictures. So I've adjusted the bar and every break is just breaking off the corner of the tile :/It looks like it.
I’ll be honest- I’ve not throughly read the instructions but I did adjust the height last week and it made all the difference. The cuts were far better. Give it a go.
about 10-20mm the near end closest to the T-bar and is breaking off mostly. Sometimes the far end.How far in from the end of the tile are you breaking and which corner is breaking near or far
Yup, been doing that every time. The manual also says to score the tile 2-3 times for tiles with rough surfaces (like the tiles I have) but it's just breaking off pieces of the slice I want to cutDon’t forget to score back that first 15mm or whatever before you do your push score on the rest of the tile
Reply to Recommended cutter for 1200mm porcelain in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
