Discuss Recommended cutter for 1200mm porcelain in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
James De
588
London
You "tap" rather than "press" the breaker bar.
Yeah that’s what I was doing.. the sales rep showed me how to use it. I’ve just managed to break off the corner of the piece I wanted :mad: but I can use the remaining part if I can get the rest off which is fine.
Anyone know if these particular tiles are harder than normal? (Is aware that may be a stupid question but I feel pretty stupid right now so what can you do)
L
LM
Make sure your score has a good sound to it and try and level the tile up a bit with a packet of some discription at the far corner which is tilting down. Keep the larger side of the tile to the left as Antonio says. Once scored gently apply pressure with the breaker about 15/20mm back from the top end of the tile until you hear the glaze break a little and no more, then bring the handle back to the bar end and at 15/20mm back from the edge apply the handle so it’s firm then give a quick tap to snap the tile.
There aren’t any measuring lines so it’s kinda hard to gauge what that is?
There is a Mark on the handle for bar setting . Look in the brochure to see it .
Are we making the assumption he is right handed
Q
Qwerty
On 1200 tiles I break first at bar end then at far end. I use pressure rather than a sudden snapping action but both methods should break it just fine
Boggs
1,118
Uk
If all fails break them over your knee
Reply to Recommended cutter for 1200mm porcelain in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
