Discuss aquaflex montolit....................... in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Italy
I tried aquaflex this morning,
only 2/3 cuts, first impression is good
more speed (but it depends a lot on the tile match).
with that blade cover I need training.
The box Antonio, is it just a water pump?
Does it have high water pressure?
The water guard, it obscures your view?
Italy
The box Antonio, is it just a water pump? yes, with a bit of electronics
Does it have high water pressure?I cut at the minimum pressure, you can have a lot of water
no marc, is mounted above the original blade guard.
but the blade is visible, almost like not having.
I need only practice because the weight is all forward now.
Concrete guy
A that price you'd be better buying a dedicated water fed stone saw for 20mm Porcelain.
FLEX CS60 Wet or Rubi or other equivalents. You also then get the benefit of a 180mm blade and increased power plus a guide rail like a plunge saw.
It seems like an expensive solution for a problem that's already been solved by better equipment.
Italy
stay calm, I know what I do
by chance, do you know how much I paid aquaflex?
because I see that you know everything.
to cut 20mm of porcelain
you want to compare the cutting speed
of a grinder with a wet saw?
I only tell you that the speed is the same if the grinder is dry.
with a tcs montolit blade (the best ever), not with the ones you sell.
but if you do the water grinder ..... the time decreases a lot.
who wants to understand understands
who does not want to, keep looking in his square meter
Italy
turned on this morning at 6.45, off at 15.30.
I did 4 times full of water.
what to say? double cutting speed, for now tired but satisfied.
Reply to aquaflex montolit....................... in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
Lowpaul22
