everything Marc has already said - 100% spot on.
out of interest - what manufacturer/brand are the tiles?
Discuss Glazed porcelain cutting issues in the Canada Tile Advice area at TilersForums.com.
Tried doing just a shallow pass with angle grinder but still same, photo above is only 2-3mm into depth if tile and then the split.Instead of going full depth on the cut make a first pass at half depth along the full length of the cut using a sponge to cool the disc and cut . Do drill corner first though . Then cut full depth say first 2 inches each end of the cut then full depth next to corner drill hole say 2inches then cut the rest out .
Try putting some carpet on your work bench to help dissipate the high frequency resoresonance from the cutting of the tileTried doing just a shallow pass with angle grinder but still same, photo above is only 2-3mm into depth if tile and then the split.
It costs more to send the rep out than it does to replace the whole order, yet they make us jump thro hoops to prove we’re not idiots and can cut a tile with a wet machine.He thinks tbey may have been over fired and are getting intouch with the factory in india.
Reply to Glazed porcelain cutting issues in the Canada Tile Advice area at TilersForums.com
