Shinyshiny054
hi all,
I wrote some time back about issues with ufh system, we managed to get this laid and poured a screed over to level the floor. The screed wasn’t perfectly level but there wasn’t a great deal of variance across the floor. We employed a tiler as opposed to DIY due to large format tiles that varied a little in size plus the area to tile was vast and we wanted the best finish possible - hence calling in a professional. The work was completed on Thursday and I am concerned with the lippage of the tiles. I have contacted the tiler who says the problem was with the tiles being different sizes. To be clear, these weren’t expensive tiles, they varied between 603 and 605mm sq. could this be a valid reason for the lippage?
Further point - I asked about the shoddy grout work and was advised this was due to low lighting conditions (alarm bell!)
Further point - I asked if the high points on the floor should be ground down to give a flatter floor and was advised that it was within tolerance and wouldn’t affect the job.
Advice please - is this lippage acceptable?
Thnk you
Thnk you
