Currently reading:
Grout Cracking despite rakeing it out and doing it again
Discuss Grout Cracking despite rakeing it out and doing it again in the Tile Adhesive / Grout Advice area at TilersForums.com.
Weebisto
hi all, did a bathroom and a kitchen floor this week. Used standard set addy which gave me a bit more time to work. Left it for a good 24 hours before grouting Plywood subfloor installed by joiner and sealed with latex sealant by me before being left to dry and then tiled. Grout in bathroom fine but grout in kitchen showing lots of cracks. Went back in today and mixed grout a little thicker in case that was the issue, raked out affected areas, cleaned and re-grouted. Been back to check and although not fully dry it's not as bad but still cracking has appeared. Heating on full bung so wondered if it's dried too fast? Alternatively, could it be movement on the sub floor?
Any suggestions appreciated
Weebisto
Almost certainly movement due to poor substrate prep. Or it could be wrong grout. Or it could be a few other things. We need the details of what tiles, how they were fixed, what with and what to.
Ok so tiles were ceramic from b&q 60x30, plywood subfloor installed by joiner, I sealed it using mapei latex sealer, fixed using Larsen std set adhesive 100% coverage and left for 24 hrs then grouted using mapei grout from Tile Giant....twice
Q
Qwerty
@Weebisto correct me if I'm wrong, but you dont seem to be having too much luck with tiling!? At the start of the month you posted this thread-
After a knock to confidence, back at it tiling a floor - https://www.tilersforums.com/threads/after-a-knock-to-confidence-back-at-it-tiling-a-floor.85106/#post-890700
and said in there .....
Back in the saddle this week with an ensuite floor that needs old adhesive removed, backer board installed and sealed then tiled. Using Mapei Keraquick with 100% coverage and will be working from a centre point and using tile levelling system.
Any words of wisdom? This one has to go well
Why did you chose to tile to wood when you knew backer board was the correct method. There was plenty of pointers for you by members in that post.
My advice to you is to know your limits and proceed with tiling with caution. You have had problems with a couple of jobs now and run the risk of doing your reputation more harm than good. This latest floor will keep failing (with movement) and you will have to take it all up and start again. But who will pay for this, you or the customer?
Bathfix Bob
588
[Distant sound of gunshot]
I know the last time i tiled on plywood floor it failed and that was 2010, I did tile an 18mm plywood countertop for a basin this year and due to thickness constrains I couldn't add another 6mm so i had to tile straight to the ply and i remember the grout cracked as soon as it dried with no weight on the countertop.
God knows what that was all about.
GAZ5518
558
EPSOM
Cracking probably due to either movement or delamination...I will always prime floor at least twice and then Bal rapid mat on any ply I come across failing that 6mm hard I backer or the like...
Flexible adhesives and grouts whilst a must, can only deal with a certain amount of deflection etc..
Once again ....as the others will tell you ...preparation is key...:rolleyes:
Reply to Grout Cracking despite rakeing it out and doing it again in the Tile Adhesive / Grout Advice area at TilersForums.com
