Discuss Optimax Heavy Duty Expansion Joint in the DIY Tiling Forum area at TilersForums.com.
P
paulphur
If laying 10mm porcelain would a 12.5mm floor Optimax Heavy Duty Expansion Joint be the one to get?
L
LM
Well a 10mm would be of no use. It’s making sure you perinatal the expansion trim and then being attentive to the bedding of adhesive that you apply, if done correctly then that trim should be fine. I normally allow about 2mm for adhesive but it depends on the format size of your tile. A 300x300 will sink more into the bed than a 600x600. What size of tile are you fitting and what type and size of notch are all factors to consider.
Please explain "perinatal"???!
Reply to Optimax Heavy Duty Expansion Joint in the DIY Tiling Forum area at TilersForums.com
  • Sticky
