Discuss Kitchen floor preparation in the Canada Tile Advice area at TilersForums.com.
476
Good evening. It's been a while..
I always visit when I need reliable advice, this is the most helpful forum I know.
As you can see, we are replacing our kitchen and at the same time have removed a floating timber floor and 50mm batterns/insulation for tile preparation. Today I have installed 18mm ply on 50mm batterns for the kitchen base units to sit on. Unfortunately my trusted tiler is not available until after the kitchen is fitted hence why we are not tiling the full room.
In the concrete slab area I have prepared for 50mm Marmox boards by using with a sealer/primer. Once the boards are fitted with flex tile adhesive porcelain floor tiles will be laid.
My questions -
How should I deal with the water pipes consisting hot and cold plus cental heating? They are not quite siting at 50mm height but should I chase into the concrete slab?
Typically what is the distance from the wall to the front base unit feet? Kitchen supplier couldn't give me a clear answer.
Does anyone see any problems with my work so far?
476
Good morning. I plan to start fitting the Marmox boards this morning. Should I work around the water pipes until I have a plan for them?
438
Balham SW12 0NJ,
Thanks Dontiler. Do you often see pipes like this that are then buried under the floor?
No, but don't think you have other option, I would probably asked builders to rise floor on battens, screw marine ply down, and then I would overboard it with 6mm cement board + ditra if you installing stone. That way you would not need to chase anything.
macten
1,158
Nottingham
Am doing pretty much same thing on current job. Lots of polypipe and HDMI cables:
476
I agree this sounds like a smart route. Aim was to get the insulation back in so Marmox was chosen. Looking at pipes where they connect to a radiator I'm not going to get these into the floor.
Reply to Kitchen floor preparation in the Canada Tile Advice area at TilersForums.com
