Discuss 70m2 Floor, 2 substrates, Ditra and Hardie? in the Canada Tile Advice area at TilersForums.com.
How big is the area with the caber floor? Is there a possibility of filling it in? To prevent any bounce as that is where your going to coma across with problems
How do you mean as there is ufh under timber . Do you mean take out floor and screed
Yes thatnis what I was trying to say but without pictures it’s hard to gauge, maybe pump a liquid screed ?
It would be hard as you would have to get a Dpm in there . I would say remove flooring , joists and ufh before digging out then starting to put things back together .
clipboard2008
The underfloor heating is already installed by the builder between the joists. It is set in a tray which is then filled with screed to transfer heat. It's quite popular as it allows you to put underfloor heating on second floors. This is obviously a ground floor.
Certainly can't fill underneath the caber flooring.
My plan is to hardie backer the floor then ditra matt it. I know it's a costly option but it's the only way I can see of ensure it's stable enough so it doesn't crack?
I wonder how many builders get structural engineers calculations on that before loading the joists up with screed
Spare Tool
The problem you've got here is no...or should I say not many ;) tilers on here will give you advise to just uncouple and tile over two substrates without following the joint directly through into the tiles, had this dilemma with customers before and tiles have cracked (I told em so :)) then again some haven't.
I've used silicone to adhere tiles across a joint before on a job that had cracked to remedy and it worked , used marmox boards plus a crackmatt only this year as a customer didn't want a dodgy shaped concrete to wood expansion joint in her floor and up to now its been fine, there is no defining answer, you won't get any guarantees off anyone unless you do it by the book, otherwise its a gamble and I'm afraid your stuck between a rock and a hard place with this one.
Bond
518
Highland
If there is access and enough space in the sub-floor area, you could add beams or other support to the floor joists.
Reply to 70m2 Floor, 2 substrates, Ditra and Hardie? in the Canada Tile Advice area at TilersForums.com
