Discuss Setting out Herringbone pattern in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Jimbobble
Never done a herringbone pattern before.
What to watch out for please boyos?
Ta,
Jim.
Spend lots of time measuring, it's tricky setting out but once your into it it's ok
Jimbobble
Same as a half bond metro set out but more to think about? Going to have a play about when I get a spare moment tomorrow. The B&Q video was funny
Spare Tool
Its only the same as half bond metro set out if its 90 degrees, for 45 I'd be striking a line up centre of wall then drylay a row or two on the floor and measure off it then transfer measures to wall...if it is walls that is?
Spacey360
Dont start with tile points on centre line or you'll get different size cuts either side
Theres 2 ways set out herringbone on a 45
First is to draw a line down the centre of a tile at 45 degree's and line that up on your centre line. Cuts will be equal sizes but opposite way around.
Second way to get the cuts the same way so they are like wings ( best way imo) is a bit more complicated to explain easy to show. Set two tiles herringboned and measure the distance between the points of each tiles but parallel. Then quater it and measure that distance off your centre line and thats you new line to start from off the points. If that makes sense
For example I use alot of 3x9 inch parquet tiles so id be starting 26mm off my centre line to get equal cuts on each side going the same way
Blunt Tool
Measure room in mm at precisely 23 centigrade, take latitude and longitude readings and times by length and breadth of room mm and divide by 23, find square root then calculate the curvature of the earth and take note of time add 4 then divide by 2, this will give you starting point!
Andy Allen
You could always frame the wall or floor makes life easier for the cuts....
This is one I did last year..
Just do what I do when setting out and guess . It always works
Did you ever work for a technical dept of an adhesive company because those are the questions they asked me when I said their adhesive had failed.
Jimbobble
Very nice.
It's a dog tooth finish on the top they're after.
I still cannot see the logic in starting in the middle & hoping for the best. Goes against everything I was taught in setting out properly. Surely there's a better way than starting in the mid point & hoping to avoid little pieces?
I'll keep the border technique in mind for future jobs, looks really smart that. Nice choice of tiles too :)
Spare Tool
Very nice.
Dry lay and a tape measure or staff Jim...not hope for the best ;)
Blunt Tool
Ping chalk lines diagonal corner to corner, check for square, then staff out is what I'd be doing, simple and easy!
Reply to Setting out Herringbone pattern in the Canada area at TilersForums.com
Apatel
