Currently reading:
Large floor
Discuss Large floor in the Canada Tile Advice area at TilersForums.com.
L
LM
I have a 180 sqm Floor to tile on s and c screed with ufh . Customer does not want to use movement membrane (ditra ,dural etc ) I won't do it without. Just wondering how many of you would .
I would need more details of the tile to be used and layout/dimensions of the area.
Have exspansion joints been incorporated into the screed in the correct locations already?
As above has the UFH been commissioned properly?
All things being equal then yes I would tile it.
Uncoupling Theory Explained (Part 2) | Schlüter-Systems - http://www.schluter.co.uk/uncoupling-theory-explained-part-2.aspx
paragraph 7 - "Neutralising stresses by uncoupling the building structure from the tile is particularly important with the use of today's thinner, larger-format tiles and lightweight building materials. "
Have they added to this now???
If solid-bedded, I'd be very amazed if a high heel could damage 4mm porcelain on ditra.
Not saying it's impossible but I can't see it myself, even with a 24 stone lady in louboutins!
Reply to Large floor in the Canada Tile Advice area at TilersForums.com
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
Hi all. Just wanting some advice and wondering what the pros in here are using nowadays for cutting large format porc? Ive been relatively lucky up until recently and been able to cut most of...
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
