Discuss Myson Micro Board piped heating boards.. in the Tiling on Underfloor Heating area at TilersForums.com.
Are you fitting it merl?
Sorry I don't know you very well so I don't know if you have a plumbing background.
It just looks like Polypipe overlay to me.
You'd need to find out if it's a gypsum based or cement based board, then you'll know how to prep it for tiling.
I agree, their tech sheet is next to useless! Haha
1,223
On a rock in the middle of the sea.
Im not doing the plumbing element of the works but ive said id rather prep the concrete and install the boards for the plumber to pipe it up prior to tiling. Do you adhesive fix the Polypipe boards?
1,223
Looks virtually the same except colour Julian.
The plumber is supplying the system so would rather leave it to him.
Do you need to self level over the pipes before tiling?
J Sid
just prep floor as if tiling it, prime underside if boards with a acrylic prime, once dry stick down with cement based adhesive.
fix pipes in and prime top side. I normally uncouple with Ditra, other may use a different make and tile away.
a very good price as well
If you get the chance, pressurise system before the slc, that way when slc dries and system is drained you'll have a little room for expansion of pipes down the line. Pressurise as high as you can.
1,223
Will be installed alling the boards and leaving to for the plumber to pipe up and commission mate, then will return to SLC and tile. Cheers for the tip.!
Reply to Myson Micro Board piped heating boards.. in the Tiling on Underfloor Heating area at TilersForums.com
Hi all. I came across this forum searching for info so my first post. I'm renovating 1890's...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
