Discuss Travertine : can/should it be laid flat? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
What a shame:(
sadly it's a common theme on tile forums though. fixing stone and tile to a high standard is a specialist skill.
Fixing tile and stone to a 'general' standard, well that's what you have here.
I'm still amazed though that some people view that kind of standard as acceptable!
How about grinding and polishing rather than a full rip out? Unless of course it's been spot fixed...
A typical builder job, poor prep, if the floor was sound to start with these lips wouldn't or shouldn't be there.
A
AllyCa
Thank you to everyone for all your comments. This has been very useful, and helped in my conversations with the builder. Just another quick question, if you have time : if there was any other solution for making this good which didn't involve lifting the whole floor and starting again, what would you suggest? Someone has mentioned grinding and polishing. Is there anything else? I'm just interested in knowing all the options available. Many thanks!
H
hmtiling
What a shame:(
If it's been spot fixed and still that bad then the guy needs shooting!
H
hmtiling
I think they're your 2 options
A
AllyCa
Can you grind and polish trav that much ? Looks half of the thickness in some pics
That would be my worry - to level it out, tile-to-tile, would it be such a difference that the tile would then not be flat with itself? Or might even need to be ground down too far?
gamma38
1,058
Bedford
Your only option really is to rip it up and start again. Unfortunately this puts all the stress your way. You have to either pay for it all again with someone else doing the job. Or go down the route of getting money out of your builder. I would say your builder would be reluctant to cough up a load of money. I wouldn't grind it down, as said above.
Reply to Travertine : can/should it be laid flat? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
  • Sticky
