Was wondering how long until I could tile a liquid screed. I hear its 1 day per mm depth. Is that right? Any specific primer needed for liquid screed? Im tiling limestone on top of it. Thanks for advice in advance
Discuss Liquid screed drying times in the Canada Tile Advice area at TilersForums.com.
Sounds like gypsum based to me. Any ufh? If not a mm per day believe up to a certain depth but can then be more it unusually deep. Cash be force dried with ufh. Should be sanded, heating commissioned and primed. I'd use a decoupler with stone and gypsum based adhesive under it then cement based on top for cost reasons. Loads of threads on here about anhydride/anhydrite screeds.
You need to find out if it's gypsum based or traditional sand and cement screed.Thanks guys, it's fibre reinforced and 40mm deep with under floor heating in it. How long is it until the ufh can get turned on to start drying it out? Once dried out sand it to a rough surface, then prime, then gypsum based adhesive then decoupler then flex adhesive?? Why gypsum adhesive and not flex cement based? Cheers
Fibre Screed - Fibre Screed - [DLMURL="http://www.premiermortars.co.uk/screeds/fibre-screed"]Fibre Screed - http://www.premiermortars.co.uk/screeds/fibre-screed[/DLMURL]Hope it's gypsum at only 40mm!
UFH?Fibre Screed - Fibre Screed - [DLMURL="http://www.premiermortars.co.uk/screeds/fibre-screed"]Fibre Screed - http://www.premiermortars.co.uk/screeds/fibre-screed[/DLMURL]
Reply to Liquid screed drying times in the Canada Tile Advice area at TilersForums.com
