Floating floor replacement
A
ARC123
Hi.
I've discovered I'm the not too lucky owner of a Floating Floor, 18mm chipboard on 25mm insulation, supported by concrete "block and beam" I'm having a new kitchen and when the old tiled floor came up (slate on 18mm chip ply) we found the dreaded floating floor below. The old floor had flex in several places and some tiles were loose or cracked. All the advice I've seen so far is "Don't tile on it" ! So it's coming up and I need to replace it with something which will take 450mmx450mm ceramic tiles and last as long as I do. Going for alternative surfacing us not an option as I want the tiles to match those in an adjacent conservatory and they were bought on special order. The Difference in Levels between the rooms is not a problem as there are steps between the two.
Question is what to put down instead? I need to make a decision ASAP. All advice from those who have experience of this most welcome.
Andy
What height have you got to play with? Ideally you'd put 100mm insulation with a minimum 70mm screed (less if anhydrite is used, 40mm possibly), do you have that sort of room with doors etc.
Hi Bri.
Thanks for the quick reply. Unfortunately I've only got around 60mm to play with , plus the tile bed and tiles.
Could use 50mm marmox boards
Thanks for the suggestion.
I've just checked these out , would you lay them directly onto the block and beam with a bed of tile cement or would you need to put a self levelling compound onto the block and beam first ?
There will be a 2mx1m island unit with a granite worktop going on this floor so it needs to be solid.
block and beam floor simple expanding metal screed 30 mm lay tiles into wet screed should get at least 100 years + out of it you need to look for a tiler who has the know how no problem for them and it should be finished in 1 day with next day grouting fix kitchen two days later
Hi. I can see how that would be very rigid but if I've got it right I'd not have any insulation under the floor and I'm not having under floor heating.
6 mm insulation board will give you the same insulation as 100 mm on a block and beam floor
ARC123,
J Sid,
ARC123,
J Sid,
