Currently reading:
Plank Tiles
Discuss Plank Tiles in the Australia Tiling Forum area at TilersForums.com.
terrycoe1
That looks nice, Tough call on set out. I see a fairly even split tile on your bottom and top cut. The tile on around the window edge must have been a pain to cut. I might have popped a bit of plaster board on the sill to help save on that cut but I can't see what else is in the room. Nice floor by the way. :thumbsup:
Yeh there was a horrid edge around near the door if I'd dropped it I would have had the same slither but 3 or 4 tiles long and the window edge would have ended up a full tile which run out I was passed the job on prep work was done by someone else I should have used plaster board or Evan off cut of tile under neath to pack it up !
Reply to Plank Tiles in the Australia Tiling Forum area at TilersForums.com
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
