Discuss Dry Mapei Grout Removal From Textured Porceiain Wall Tiles in the Australia Tiling Forum area at TilersForums.com.
Lithofin BOB
508
Hampshire
As above , our alkali cleaner is lithofin intensive cleaner, which can break down polymer in cases. Grimex mention above ,I think is an alkali this may do if you have some.
Again dilute , pad on with pad, let the product work 10-12 min , scrub every min , rinse
Got ant photos of this contamination
Dan
Admin
1,318
Staffordshire, UK
Hi
I have just grouted my newly fitted ABK Reworks Multi Beige 600x300 Porcelain wall tiles with Mapei Ultracolour beige grout.
The tiles are textured matt to look like natural stone. The problem is the grout has ended up going into the surface undulations and I have been unable to clean it out fully before it has dried.
What can I use (products and techniques) to remove the dried in grout as it looks really messy and obvious?
Thanks.
Did you manage to sort this problem out?
Reply to Dry Mapei Grout Removal From Textured Porceiain Wall Tiles in the Australia Tiling Forum area at TilersForums.com
