Dewalt d24000 vs Montolit tornado vs rubi dw250n
I've decided to buy a Dewalt D24000 when my Rubi ND 200 packs in, which I expected it to do long before now, but still going strong, even after a serious amount of heavy work - code for abuse ! - That said - this Rubi model is the table saw model - not the overhead rail your talking about. I dont know how effective the Dewalt will be at cutting switchboxes out of whole tiles as the smaller the dia of the wheel, be better it is at that specifc task.
I would suggest that if you can afford it, buy a Rubi ND Model 200/250 stainless bed and also a D24000. The Rubi table top version as one massive advantage over every other type of wet saw - inc our DR300 EN ! in that it will cut any length of cut - infinity [as long as you can support the tile and the cut-off. ie we have cut 1200mm porcelain on ours, whereas the D24000 is limited to about 800mm or something like that - not sure without checking but my memory [going as rusty as my Rubi !] says its 750/850mm ish !
Hope this helps
PS - Dave at Tiletrader knows I will give a call one day - Just not yet.
:thumbsup:
Hi Richard,
You could get a D24000 and the new Montolit 85mm diamond wheel for your grinder - this will cut out a single socket with the greatest of ease:thumbsup:
Hope this helps
:thumbsup:
So will a sigma 10M
But it costs a lot more money.
:thumbsup:
We find the dewalt saw and a 4" grinder with a decent blade along with either a hand diamond pad or an electroface diamond pad on a variable speed grinder (you can pick up a cheap one for £35 on ebay and as you only use them intermittently they last ages) plus a set of diamond hole saws is enough to do virtually anything we get asked for. When we are working with the larger format porcelain we use the larger Rubi TX snap cutters to suit the tile. We only use the wet saw where its necessary.
Terry
I have a table saw as well as the Dewalt one..
My table saw is the Rubi Diamant D200 and is well above the ND200 for quality.. iv'e had the same cutter for yrs and yrs.. it is fully stainless steel and sits in the water tray rather than a slide in one... marvellous cutter for power etc but for the amount of stone work i do then it had to be the dewalt over the Rubi dw250n i had..
For virtually unlimited cuttig length I use a Festo circular saw fitted with a diamond blade with the 3 metre guide. Beats the hell out of dragging a BAM machine to site and setting it up just for a few long cuts.
Terry
Hi Terry
I'm a big Festool fan, got a load of their gear.
I will have to start useing a diamond blade and tracks with their plunge saw for Ezystone worktops.
Once you used the plunge saw and tracks with a diamond blade, does it damage the saw or tracks or can I easily you go back to a wood cutting blade? or do I need to get another plunge saw one for wood and one for stone?
Thanks Richard
Depends what you mean by damage.....obviously it gets dusty and I am sure your average carpenter would be more than a little disgruntled if you borrowed his Festo, used it for the purpose I describe and then gave it back to him, but if like me you regard tools as items you use and abuse occasionally when justified then its fine and I regularly swap my saw from wood to stone and back as I require and its been fine so far.......but obviously your waranty is out of the window the moment you cut stone with it.
Regards
Terry
Thanks for that,
I always use Festools dust extraction with all the cutting I do, so hopfully it won't bugger up the anti-splintering devices attached to the tracks or the internails of the plunge saw.
"Hopefully" 🙂
I did it as an experiment on a big job that I cold afford to write off the saw to and I cant help myself when it comes to trying alternative methods to solve a problem. So if anyone else is following in my path then good for you but please be aware that if you are using somthing for somthing other than what it was designed for then if it breaks you are on your own:thumbsdown:😳:mad2:. However if it works and saves you loads of time you are a winner :hurray:
Heres to pushing the envelope as far as tool use/abuse goes 🙂
Terry
PS another little tip, buy one of those little kettle elements for heating a single cup of tea whilst camping (they work on 110 and 240) and put it in the resevoir of your wet saw whilst working outside in the winter (make sure the element cant come in contact with the tray if its plastic!) then you will find that he water that used to freeze your fingers is luke warm 🙂
ross9807,
Aston,
ross9807,
Aston,
