R
Rob Z
Hi Dingers and Ajax,
The figures quoted by our TCNA (Tile Council of North America) are a bit more conservative than what have been posted here, and as far as I know they don't make any distinction about the type of substrate and the required joint spacing. They also want to see those joints go all the way down through the layer on top, whether it be a mud bed, gypsum screed, etc. Schluter Dilex is a good product to use for this although after the fact it isn't an option.
I think one of the best rules of thumb to follow are the guidelines given by Schluter: place soft joints in all doorways (ie: divide up all rooms as separate fields of tile), have a clean perimeter joint all around the room (filled either with sealant or nothing at all-no grout or setting material, and cover with base trim), and ensure that all fields of tile are in either squares (not always possible) or rectangles that have a ratio of the sides not to exceed 1:1.5.
Dingers, did they install foam around the perimeters of all the walls so the pour will be separated from the house?
