Dot & Dab Quandry
Thanks everyone... I will post the outcome when I finally get it resolved. Just to clarify we hadnt fully finsihed the room and it hadnt been in use so the kids are safe and sound.. :hurray::hurray: + thanks again for the technical help, Time for a beer me thinks :8:
Well deserved one i'd say.
Just follow the advice you've been givin and you'll be fine
dot and dab is a common method used by non tilers as it saves on addy and is easier to adjust when fixing
adhesive manufacturers reccomend min 70% coverage but most tilers work on 90% min
porcelain are dense and therefore heavier than biscuit and need a good purchase to the substrate
another advantage of 90% coverage is when you press the tile in you push the air out creating suction holding the tile where you placed it
youve been given sound advice on here
with care you will be able to remove all the tiles and clean them ready for reuse
score through the painted surfaces and then prime, dont just prime as the primer wont penetrate the paint and the paint may seperate from the wall dropping your tiles
good luck mate
its difficult when mates or family help out as you dont want to fall out with them but you really cant leave this and the sooner they are off the softer the addy
mike
ps i gave up smoking last week after 40 yrs , i can reccomend as ive got a new lease of life................still climbing the walls though
good luck mate
mike
stick with it Mike, I gave up 2 1/2 months ago, don't even think about it now!
Deja Vu - except mine was a "Tiler" - supposedly!!!:thumbsdown:
I am having my tiles ripped out due to dodgy fixing (and also cr@p quality) :mad2:
Good luck with it
Steve
sorry to say you need to rip them off. but if they are coming off that easy you should be able save most of them and keep the costs down. re the painted wall i wold strongly suggest getting all the paint off. i use a 4"razor scraper, as i find this the fastest method.just make sure you prime and use a good quality flexible powdered addy(using a notched trowel of course).
sorry to hear about your situation, hope it goes well, p.s. dont forget to seal the tiles befofe grouting,with them being polished porcelain,
I'm sad to say that I spent 2 days last week retiling a bathroom that echos similar circumstances to your own. They were the same tiles and were fixed with cement based adhesive, dot and dab on to emulsioned walls. The whole wall of tiles had dropped 3mm opening up a grout line basically resting on the bath held together by grout. They also failed in the shower where it wasn't painted. I re-prepped the walls by stripping all the paint left on the walls (the rest was on the tiles i removed), I then keyed the walls a lot to rough them up and then primed with SBR primer. I fixed them to the wall with a 10mm trowel then by spreading the wall and then the tile. I am pretty confident this will be enough. I cannot stress the importance of fixing porcelain solidly to walls, it is ridiculously heavy and possibly dangerous. Good luck
Dot & Dab Quandry
artfuldodger,
faceman,
artfuldodger,
faceman,
