Wetroom wall waterproofing
GBH
Hi, I am about to start a wetroom project. The wetroom floor is concrete screed. I will be cutting into the screed to insert an Impey shower former at 25mm deep. The walls are 15mm thick plasterboard on dabs on 100mm thick lightweight blockwork. The plasterboard walls are showing signs of shrinkage in the corners where (i.e. small hairline cracks) the skimming has dried out over the past year.
Be glad of some advice as to the best products to use to waterproof the floor and walls.
Hi
Waterproof installation with Mapei Mapegum WPS using Mapeband in the internal vertical corners and at junction of walls and floor.
Tile in a solid bed of Keraquick or Adesilex P9 and grout the joints between the tiles with Ultracolor Plus (26 colours). If a water impervious grout is preferred then use Kerapoxy (26 colours).
Provide joints at floor perimeter, internal vertical corners and around fixtures and fittings and fill with Mapesil AC (27 colours)
best of luck
dock
Hi GBH
Quite simply I would tape your corner and floor to wall joints using Durabase flexible tapes which will move with the building and prevent leaks worries further down the road. When the tapes are in place fix Durabase WP membrane to your walls using a flexible tile adhesive, this membrane comes on a roll and is real easy to use.
The above will sort out your waterproofing and can be found at www.wetdecs.co.uk or if you want a personal quote including an impey base or further help please email me
Cheers
tiler
Hi GBH
Cheers
tiler
good simple advice wetdec ,but where can you buy these products in a hurry...lol...pmsl...good one dad.:lol:
I love how these threads end up as advertorials! Brilliant
Its very easy to say but there is far more advice than advert and if the guy was living in Preston looking for a tiler you wouldnt reply then ?
Overnight from us if your in a hurry or maybe you would rather pop into b&q and buy them there with free advice.
Where do you buy your wet room kits then guys ???
tiler
Normally i use wedi systems from CTD....as i get customer to pay for them it is normally not a price issue.....but i like the look of your trays wetdecs so don't be surprised if i call you......:grin:
Thanks Dave this Tilux base is in my opinion the best solution on the market.
It :
Has a pre installed waste system so no leak worries like others you have to put together yourself
Has a factory fixed waterproof membrane again this is sealed into the waste / trap collar solving sealing around the d drain
Provides an overlap of waterproof membrane around the base making sealing to walls and floors straight forward
Can be used with both wood and concrete floors
Can be cut to shape without weakening
Has gulley hight adjustment to take tiles up to 22mm
Has an overall instal height of 105mm,
Is exceptionally strong and light can be used with tiles and Vinyl unlike Marmox, Wedi board, Varme, Showerlay and No more ply Wet room shower tray formers
Will think of another for you 😉
tiler:thumbsup:
Just want to correct you on a couple of points Wetdec. Kaskade/NoMorePly actually produce "vinyl" trays as do "Showerstone" a.k.a. Marmox.
New players to the Market - Wickes - wetroom tray looks unecessarily complicated. Also "Roman" the shower screen people have brought out a solid former - looks very impressive - 4 sizes.
There is nothing complicated about fixing a trap to a tray, Dallmer supply 90% of the market - for Schluter, Wedi, Kaskade, Impey, Marmox and many many more.
There are many products out there, I could sell - in making my descision what I sell, I look for ease of installation, robust quality product that is capable of handling high point loading (such as a wheelchair), and reasonable price.:thumbsup:
GBH,
wetdec,
GBH,
wetdec,
