Discuss Good Flex Adhesives For Floors? in the UK Tiling Forum area at TilersForums.com.
N
nickwebster6a
Hi,
as a new comer to the trade (have just completed a course at north east tiling training) I am tiling a bathroom floor which is tongue and groove. Should I lay ply and use flexi adhesive and grout ( any suggestions on brands gratefully received) or is there any other way of doing it? I've heard talk of an adhesive you can use on floor boards but don't know any thing about it.
nick :thumbsup:
Reply to Good Flex Adhesives For Floors? in the UK Tiling Forum area at TilersForums.com
  • Question
  • Question
  • Question
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
  • Question
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
