tile cutters
i have both rubi and sigma cutters!! the sigma is overlooked by a lot of tilers but trust me its a great cutter!! would u agree gaz ??
absolutly the sigmas are far the superior cutter, very robust, i have a sigma 15 year old still going strong
Ive always used rubi both wet and dry, have four in total, always fancied a sigma though, whats the benefits?
Never used a sigma Kap,but if your vision isn't impared with dangling snapper bits,I'd probably like it.Do like all Rubi stuff,always use wedges essential bit of kit for detailed work.
the rubis weakpoint is diagonal cutting, the sigmas are great for this!! ive used the rubis tx cutters but i dont like them too heavy and fiddly to use!!
A snap cutter can not have a weak point surely!!The rubi snapper will give you an accurate line (within a pencil point)It is the(crack the tile) bit that is in question....am I wrong?If a tile does not want to break along a weakened score line in its glaze ....why slag the cutter ..slag the operator,try a different method like wet saw,I know we havn't got the time have we??????:angry:
gaz gaz gaz keep your hair on m8!! the rubis a great cutter but the sigma is much better for diagonal cutting ,if you have ever used one you will know wot i mean!!! :heart:
Most of the sigmas are pull to scribe, and i think the rubi's are push to scribe? And do the rubi's have two handles one for scribing and one for snapping, whereas the sigma's have one handle, alot quicker in my opinion
You can get a handle for the Sigmas called a "Klick Clock Handle" which allows you to push to scribe.
I mainly use rubi cutters, 3 dry and 2 wet (with marcrist blades ) which i like a lot, although i do use other brands, including a cordless makita angle grinder with a marcrist blade, a cordless makita glass/ tile saw and also a plasplugs compact plus wet saw. Unfortunatly I have never used a Sigma cutter but I would like to give one a whirl as Ive read lots of positive comments.
ebay had a couple of new sigma cutters listed recently, not sure if they will still be on there but could be worth having a look.
Always felt the pull method a bit dificult for me, although it was never a proplem in my youth! :wink_smile:
i use rubi wet and dry cutters and a makita cordless wet cutter handy as hell for little jobs , paid for itself many times over
tile cutters
jonesy7,
lm tiles,
jonesy7,
lm tiles,
