Discuss Help. Big Clinker spare cutting wheels in the UK Tiling Forum area at TilersForums.com.
jason23
Hi Folks,
Anyone know where I can get a spare cutting wheel for the 610mm Big Clinker. Got the tile cutter from screwfix and its good but I cant find spares anywhere.
The cutting wheel is 22mm and has a sealed bearing on each side of it!
Jason
Gazzer
CoopersDirect.com - Vitrex 10 0600 Big Clinker Tile Cutter 600mm - Vitrex
Vitrex 10 0602 Wheel (1) For 100600 Tile Cutter - VIT100602 - - GodfreysOnline.com - £3.95 Delivery On All Orders!
You may also find that another make will fit
Or
Try
Vitrex - a Q.E.P. Company
jason23
Thanks Mate, great stuff.
The QEP number which is 100602 is available at TOPPS under the number 020906 but they charge £12 and have to order them with 7-10 days turnaround.
I will try the link you gave me first.
I took the cutting wheel out of my clinker and there are small dropouts on the wheel here and there. I have used it for maybe 8 tiling jobs.
Does that sound like a long life for a carbide wheel to you?
I suppose it depend what you have been cutting and how much pressure you use.
CHeers
waterfd
Just bought a Big Clinker and had difficulty cutting 500 x 500 ceramic floor tiles so ended up using a wet cutter for the rest of the job. Saw QEP at the Tile and Stone show and he suggested the wheel may be bad so he gave me a new one. Good service , haven't tried it yet but from this forum the cutter has a good reputation so maybe I need to practice abit more with it. Does anyone have any suggestions about what I might be doing wrong?
Wylie
Did you solve your problem cutting the 500x500 i was thinking you could practise on the waste cuttings
E
Eddie
Have just been looking at spare cutting wheels for Big Clinker on Ebay. would have done a link but i dont know how:thumbsup:
DHTiling
If you click on my signature link ..there is some spare wheels for the clinkers in there...
Grace'sDad
Topps sell them - marked as "QEP cutting wheel" - no mention of big clinker on the package though. approx £12 from memory.
waterfd
Wylie, I have practiced and found that if I score once the tile does not break cleanly but if I score twice at the begining of the cut I can get a clean cut. Also I read the owners guide (as you should) and it says 'Apply increasing pressure on the handle until the tile snaps along the score line' this seems to work. So no sharp snaping action as this will break the tile. I will get some more tiles to practice with till I am confident.
bigneil
i have always had Rubi tile cutters generally don't have any problems, except keope porcelain floor tiles, the ordinary breaking head isn't quite powerful enough and the ts plus breaking head always chips the corner.
The reason i have only ever had rubi is because the old fella who taught me to tile only ever used them.
I'm sure there have probably been numerous threads or poles on 'best cutter' .
I'm off to look for one.
Wylie
I like the price on the clinker and thought i would go for one myself,with the push you would think it would make the cutting easy,maybe the wheel is skidding,did you try a squirt of silicon oil
waterfd
Must say I haven't but did notice when I changed the wheel if you tighten the screw too much the wheel does not revolve easily. This may be a reason. Thanks
Reply to Help. Big Clinker spare cutting wheels in the UK Tiling Forum area at TilersForums.com
Teejay
